show ospfv3 interfaces
show ospfv3 interfaces {vlan vlan_name | tunnel tunnel_name | area area_identifier | detail}
Description
Displays information about one or all OSPFv3 interfaces.
Syntax Description
vlan_name Specifies an IPv6 configured VLAN.
tunnel_name Specifies an IPv6 tunnel.
area_identifier Specifies an OSPFv3 area, a four-byte, dotted decimal number.
detail Specifies to display the information in detailed format.
Default
If no argument is specified, all OSPFv3 interfaces are displayed.
Usage Guidelines
None.
The following command shows a summary of the OSPFv3 interfaces:
The following is sample output from the command:
Interface  IPV6 Address                  AREA ID         Flags Cost    State    Nbrs
v100        2001:db8:10::2/64             0.0.0.0         -rif- 40/A    P2P      1
v101        2001:db8:20::1/64             1.0.0.0         -rif- 40/A    BDR      1
Flags : (b) BFD protection configured, (f) Interface Forwarding Enabled,
        (i) Interface OSPFv3 Enabled, (p) Passive Interface, (r) Router OSPFv3 Enable.
Cost  : (A) Automatic cost, (C) Configured cost.
The following command displays information about the OSPFv3 interface v100:
show ospfv3 interfaces "v100"
The following is sample output:
Interface           : v100               Enabled             : ENABLED
Router              : ENABLED            AreaID              : 0.0.0.0
RouterID            : 10.1.1.2           Link Type           : point-to-point
Passive             : No                 Cost                : 40/A
Priority            : 1                  Transit Delay       : 1s
Hello Interval      : 10s                Rtr Dead Time       : 40s
Retransmit Interval : 5s                 Wait Timer          : 40s
Interface ID        : 19                 Instance ID         : 0
State               : P2P                Number of state chg : 1
Hello due in        : 7s                 Number of events    : 2
Total Num of Nbrs   : 1                  Nbrs in FULL State  : 1
Hellos Rxed         : 127733             Hellos Txed         : 127739
DB Description Rxed : 4                  DB Description Txed : 3
LSA Request Rxed    : 1                  LSA Request Txed    : 1
LSA Update Rxed     : 2121               LSA Update Txed     : 6156
LSA Ack Rxed        : 5962               LSA Ack Txed        : 2121
In Discards         : 0
DR RtId             : 0.0.0.0            BDR RtId            : 0.0.0.0
BFD Protection      : Off
Authentication      : IPsec ESP
SPI                 : 256                Algorithm           : HMAC-SHA-256
Encrypted Key String: #$bC0GrQHhqjeDABqYwnlfdihIsOhV9g==
Neighbors:
   RtrId: 10.1.1.1  IpAddr: fe80::204:96ff:fe51:ea8e  Pri: 1  Type: Auto
   State: FULL  DR: 0.0.0.0  BDR: 0.0.0.0  Dead Time: 00:00:31
   Options: 0x13 (-|R|-|-|E|V6)  Opaque LSA: No
   BFD Session State: None
The following command displays information about the OSPFv3 interface intf1 using Authentication Trailer (line 24):
# show ospfv3 interfaces intf1
Interface           : intf1              Enabled             : ENABLED
RouterID            : 0.0.0.2            Link Type           : broadcast
Interface ID        : 64                 Instance ID         : 0
State               : DR                 Number of state chg : 2
Hello due in        : 9s                 Number of events    : 5
Hellos Rxed         : 50                 Hellos Txed         : 51
DB Description Rxed : 3                  DB Description Txed : 3
LSA Update Rxed     : 2                  LSA Update Txed     : 6
LSA Ack Rxed        : 4                  LSA Ack Txed        : 1
In Discards         : 0
DR RtId             : 0.0.0.2            BDR RtId            : 0.0.0.1
Restart Helper      : None
Restart Helper Strict LSA Checking: Enabled
Authentication      : Keychain auth1
Neighbors:
   RtrId: 0.0.0.1  IpAddr: fe80::204:96ff:fe97:e9e1  Pri: 1  Type: Auto
   State: FULL  DR: 0.0.0.2  BDR: 0.0.0.1  Dead Time: 00:00:36
The following command output shows BFD protection configuration information:
HQ_10_0_4  2000::d00:202/64              0.0.0.0         -rifb 40/A    DR      1
The following command output displays the BFD session state:
# show ospfv3 interfaces {vlan} <vlan-name>
Interface           : HQ_10_0_4          Enabled             : ENABLED
RouterID            : 2.2.2.2            Link Type           : broadcast
Interface ID        : 50                 Instance ID         : 0
Hello due in        : 4s                 Number of events    : 4
Hellos Rxed         : 1306               Hellos Txed         : 1306
DB Description Rxed : 5                  DB Description Txed : 3
LSA Update Rxed     : 18                 LSA Update Txed     : 37
LSA Ack Rxed        : 36                 LSA Ack Txed        : 17
In Discards         : 0
DR RtId             : 2.2.2.2            BDR RtId            : 1.1.1.1
DR Interface addr   : fe80::201:30ff:fe10:3b16
BDR Interface addr  : fe80::201:30ff:fe10:3ae6
BFD Protection      : On
Neighbors:
    RtrId: 1.1.1.1  IpAddr: fe80::201:30ff:fe10:3ae6  Pri: 1  Type: Auto
    State: FULL  DR: 2.2.2.2  BDR: 1.1.1.1  Dead Time: 00:00:40
    BFD Session State: Pending
BFD example output was added in 15.3.2.
Support for new Link Type and State values (Link Type: point-to-point, State: P2P) were added in ExtremeXOS 15.7.1.
IPsec Authentication information was added in ExtremeXOS 31.2.
Authentication Trailer information was added in ExtremeXOS 31.3.
Platform Availability
This command is available on platforms with Base license, or higher, as described in the Switch Engine v33.1.1 Licensing Guide document.
